Corel Draw
Any OS, software in here.
Re: Corel Draw
corelDraw12 :)
jennywren
Re: Corel Draw
Post by jennywren »
I'm going to go for the x5 now all i have to do is learn how to use it,
Re: Corel Draw
reserve about year and a half then :D I got 12 and dont know 1/4 about it :)
pitkin2020
Re: Corel Draw
Post by pitkin2020 »
jennywren;32098 wrote:I'm going to go for the x5 now all i have to do is learn how to use it,
Having never used any real design software like that before (apart from publisher lol) I found it pretty easy to pickup, where as adobe illustrator is a complete nightmare. Corel is quite intuitive I found and things are where you would guess they are and what they are called. Illustrator needs a glossary of terms just to understand what things mean lol.
John G
Re: Corel Draw
Post by John G »
Just checked coreldraw 12 against x4 and your right, the import filters allow certain files to be imported in x4 that cannot be imported into 12.
logodigitizing
Re: Corel Draw
Post by logodigitizing »
pitkin2020;32102 wrote:Having never used any real design software like that before (apart from publisher lol) I found it pretty easy to pickup, where as adobe illustrator is a complete nightmare. Corel is quite intuitive I found and things are where you would guess they are and what they are called. Illustrator needs a glossary of terms just to understand what things mean lol.
lol..
personally I use Illustrator for all my design work.. I use CorelDraw for basic cutting ;)
I suppose it's what you feel comfortable with..
logobear
Re: Corel Draw
Post by logobear »
The earliest version of corel draw i had is 3!
It used to be said that the odd numbers were better .....
I have Corel 11 on a couple of machines, and X3 on another, and they are all perfectly fine, the differences to most things are not significant, just a bit more polished.
If you have an older PC, - go for an earlier version, otherwise, you may as well have the latest.
Only problem with using different versions is remembering to save in the correct (lowest) version.
schizowife
Re: Corel Draw
Post by schizowife »
I've just won X4 for £46 on ebay!
John G
Re: Corel Draw
Post by John G »
At that price, it'll be a copy then :wink:
schizowife
Re: Corel Draw
It did say 100% original sealed packaging! How will i tell if its original?
