Thank you all very much! I can't wait to get started! You'll know when my equipment arrives cos I'll be on here all the time!!!!
John - when you say reg marks...? How does this help you line up on the mug? Sorry if I'm being a bit thick..!
Thanks for sharing your images Kaz - I can only hope my first attemps are anywhere near as good as yours!!!!
Where's that delivery van got to????
Just took the plunge......!
Re: Just took the plunge......!
cut to the reg marks - this ensures the print is straight on paper - when placing on the mug you'll be able to judge if is running straight against either top or bottom of the mug. simples!!!!!
I've found that if I print to the edge if leaves marks where the tape was (that could be my inexperience though). I have left a gap either side of the image for the tape to go. I use PS5 and have set up 2 templates, I use the first template to layout the image or text, this then gets dropped into the second template which is about 10mm bigger. This gives me about 3-5 mm either side for the tape. The second template has 2 red line down the side which are my cut lines, I cut just inside the lines so they don't transfer to the cup.
That's the way it works for me so far.
Hope it's of some help
Thanks for all your help!
My equipment has arrived! Courtesy of extremely good service and greased-lightning delivery from BMS!
I think I'm ready to do a print....but....I honestly dont know how to multi print to A4 from PS2...? I have a logo, about 2" square in PS2, so I thought I could print quite a few out....can anyone please let me know how...?
Many thanks!
Many thanks!
just open up a new blank document with a trans background the same res etc at your other images
and drag and drop them onto the A4 one hey presto
Thanks Snitch! Simple when you know how!!!!!!!!!!!!!!!
Fingers crossed!
Fingers crossed!
