Just took the plunge......!
Lee
Re: Just took the plunge......!
Post by Lee »
Thank you all very much! I can't wait to get started! You'll know when my equipment arrives cos I'll be on here all the time!!!!
John - when you say reg marks...? How does this help you line up on the mug? Sorry if I'm being a bit thick..!
Thanks for sharing your images Kaz - I can only hope my first attemps are anywhere near as good as yours!!!!
Where's that delivery van got to????
John G
Post by John G »
cut to the reg marks - this ensures the print is straight on paper - when placing on the mug you'll be able to judge if is running straight against either top or bottom of the mug. simples!!!!!
danlad
Post by danlad »
I've found that if I print to the edge if leaves marks where the tape was (that could be my inexperience though). I have left a gap either side of the image for the tape to go. I use PS5 and have set up 2 templates, I use the first template to layout the image or text, this then gets dropped into the second template which is about 10mm bigger. This gives me about 3-5 mm either side for the tape. The second template has 2 red line down the side which are my cut lines, I cut just inside the lines so they don't transfer to the cup.
That's the way it works for me so far.
Hope it's of some help
Lee
Post by Lee »
Thanks for all your help!
My equipment has arrived! Courtesy of extremely good service and greased-lightning delivery from BMS!
I think I'm ready to do a print....but....I honestly dont know how to multi print to A4 from PS2...? I have a logo, about 2" square in PS2, so I thought I could print quite a few out....can anyone please let me know how...?
Many thanks!
smitch6
Post by smitch6 »
just open up a new blank document with a trans background the same res etc at your other images
and drag and drop them onto the A4 one hey presto
Lee
Post by Lee »
Thanks Snitch! Simple when you know how!!!!!!!!!!!!!!!
Fingers crossed!
