Colours have changed - No idea why!
Re: Colours have changed - No idea why!
Yep, I wanted to show how far out the colours are.
Anyway, screen grabs attached of my printer settings, I have changed the quality from High to Standard which has had no affect on the colours, obviously.
[ATTACH=CONFIG]7221[/ATTACH][ATTACH=CONFIG]7222[/ATTACH][ATTACH=CONFIG]7223[/ATTACH]
I really am at a loss now.
All I've ever done is convert the image I have made to the correct colour profile and then printed using the above settings, I then save the image to include the colour profile so I don't have to convert each time I need to print. The only thing it can be is GIMP itself in that its not doing the conversion correctly maybe? I am on the latest version 2.10.34
- vB_ID:7223
- Print3.jpg (4.15 KiB) Viewed 531 times
- vB_ID:7222
- Print2.jpg (15.33 KiB) Viewed 531 times
- vB_ID:7221
- Print1.jpg (16.94 KiB) Viewed 531 times
To be honest, that colour variation looks so far out that I would suspect blocked nozzles, maybe from the yellow ink. Have you done a recent nozzle check?
Cant be that, if you read my original post, this is the 2nd printer its doing it on and its brand new.webtrekker;152867 wrote:To be honest, that colour variation looks so far out that I would suspect blocked nozzles, maybe from the yellow ink. Have you done a recent nozzle check?
Thanks anyway.
- Mrteajunkie
- Has thanked: 6 times
- Been thanked: 3 times
Yep, I've been through this so many times, all settings are correct.Mrteajunkie;152869 wrote:Check your gimp settings against this video.
Brand new, came with the new printer.AGS;152871 wrote:Are your inks in date?
Are you 100% sure gimp is actually saving the profile - I don't know gimp but can you open the image in another document and check that the profile has been saved and applied?
As per my original thread I have been printing these for years without having to make any changes. The profile has been saved with the image, but I've also re-made the image and gone through the whole process from scratch to check whether it was something in the image and it has made no difference at all.
I cant claim to be a GIMP expert but this points at a software related issue, just wish I knew what and where.
- Mrteajunkie
What inks came with the printer?
have you got access to a laptop you can run a test print through?
Your missing something in your settings somewhere.
for it to change and then be the same on a new printer too sounds like you have accidentally changed something.
