Mug discolouring
pjn11
Re: Mug discolouring
Post by pjn11 »
I’m wondering if it’s because I’m using the Cricut mug press not a normal press
pjn11
Post by pjn11 »
Mrteajunkie;151907 wrote:And your printer nozzle checks are all clear?
Maybe too much ink on the paper and it’s still wet?
The first image is how mine used to come out when left to cool.
that last image is just awful god only knows what’s happened there. Lol
Could my warm water be too hot?
Mrteajunkie
Has thanked: 5 times
Been thanked: 3 times
Post by Mrteajunkie »
The hot water can’t get hot enough to make a difference.
sublimation starts at around 160oC I believe or around that.
JMugs
Has thanked: 10 times
Been thanked: 10 times
Post by JMugs »
Mrteajunkie;151910 wrote:The hot water can’t get hot enough to make a difference.
Agree with you there.
The mugs I had a problem with were a bad batch of coating. I sent them back as the supplier agreed. A mug I kept and left in the dishwasher had the glaze peel off after about 3 washes.
The way the ink migrated depended on which way I stood the mug as soon as it came out of the press.:wink:
pjn11
Post by pjn11 »
JMugs;151911 wrote:Agree with you there.
I did try a different mug from another supplier and that done the same too, I was wondering if my press is too hot or too long pressing.
Mrteajunkie
I would say your pressing too long.
sadly I can’t help with a cricut press as I Have never seen one or know about settings etc.
from a warm mug I am pressing at 185c for 185 seconds then straight into hot water for the paper removal.
[MENTION=1606]JMugs[/MENTION] yeah heat rises so the ink will spread upwards.
the mdp mugs don’t stop sublimation until I dunk them, even waiting 20 seconds will ruin the print.
pjn11
Post by pjn11 »
I have an update I have just done a reprint on plain paper and if you look closely the yellow tinge is in the print out hence it’s on the mugs.
Regards
Paul Image
Mrteajunkie
Whats the printer and What’s your nozzle check like?
pjn11
Post by pjn11 »
Mrteajunkie;151915 wrote:Whats the printer and What’s your nozzle check like?
Epsom can’t remember the code the nozzle check comes up ok think I have found the issue will report back later this evening.
Regards
pjn11
Post by pjn11 »
Right I believe I’ve sorted it firstly my computer hadn’t saved the printer settings so it though it was printing on normal paper, secondly the paper I was using stated on it for fabric tried the other paper I have that says for hard surfaces and I have printed one out perfect.
thanks for all your help and suggestions
