Smash Proof Boxes
Re: Smash Proof Boxes
I have usually been wrapping the mug in a bit of bubble wrap, then put it into a white gift box and then wrap that will a fair bit of bubble wrap and put it into a 5x5x5 or a 6x6x6 box.
The majority have been OK but I have had about 5 or 6 breakages.
- thecartoonman
That seems a right faff. Place in a poly mug box, tape up, stick on the postage label and despatch, never had an issue with poly mailers, you could kick them around the warehouse and still the mug is fine.NickH;145672 wrote:I have usually been wrapping the mug in a bit of bubble wrap, then put it into a white gift box and then wrap that will a fair bit of bubble wrap and put it into a 5x5x5 or a 6x6x6 box.
So you literally just post them in the poly box taped together with a label on? Any outer bag etc?
- thecartoonman
NickH;145725 wrote:So you literally just post them in the poly box taped together with a label on? Any outer bag etc?
Yep, no outer packaging cannot see the point for 1 mug. Even if I'm sending 2/3 mugs I just tape them all together, using clear tape, though I always use brown tape to seal round the join wrapping around about 3 times so it's very secure and of course you can send 3/4 mugs for the price of 1 with RM Small Parcel.
I've had to open up the poly box on a few occasions as I forgot to put the paperwork inside and it takes a while to get rid of the tape it's so secure.
I have found the poly boxes to be 100% effective in preventing breakages and you really don't need any extra packaging. The poly box is perfect, the buyer knows exactly what is is when it arrives and he then just throws it away anyway. I'm all for helping with the environment but having to print, package and send another mug because the first one was damaged it just adding to the packaging waste, this way no bubble wrap, no extra plastic or box.
When I worked for Royal Mail sorting parcels, you would see all of the polystyrene boxes coming though crumbled up to bits half broken causing a mess all over the floor.thecartoonman;145734 wrote:Yep, no outer packaging cannot see the point for 1 mug. Even if I'm sending 2/3 mugs I just tape them all together, using clear tape, though I always use brown tape to seal round the join wrapping around about 3 times so it's very secure and of course you can send 3/4 mugs for the price of 1 with RM Small Parcel.
For the same price as poly boxes (taking up half of your store room), you can buy two double walled cardboard boxes. Nice and secure.
But how is sending 10,000s of polystyrene boxes for the sake of not having to resend a few parcels good for the environment??
That's why I cover my poly boxes in a grey plastic mailing bag, to keep them intact.
Have ordered some double walled as a test, I am not 100% if the Poly Boxes will fit my mugs and they don't sell them singly.
- mnporter2001
I use the double wall smash proof boxes and have not had any issues as of yet, but I am a low volume seller sending out about 100 mugs a week.
Mark
Mark
Custom Gifts www.mugsaway.co.uk <--- A work in progress!
I used the Large size poly boxes from Custompac and could fit 10oz, 11oz Durham mugs from Listawood, and also 12oz two-tone mugs with spoons, and that included a single layer of bubble wrap around the mug for added (but probably not needed) protection.NickH;145776 wrote:Have ordered some double walled as a test, I am not 100% if the Poly Boxes will fit my mugs and they don't sell them singly.
