Something wrong
Re: Something wrong
First off, you're wasting your time without first installing an ICC profile and MAKING YOUR GRAPHICS SOFTWARE USE THE PROFILE to print. This is a very important first step. You must switch off colour management in your printer driver and let your graphics software manage colours via the ICC.
Re: Something wrong
the F instead of C is a very destinct possibility !
Re: Something wrong
Is your press reading in degrees Fahrenheit or Celsius? It's a common mistake to be sublimating at way too low a temperature, 180 deg F, instead of 180 deg C.
Re: Something wrong
it is reading at 180 Celsius I have had delivered today some samples of dyes sub printed already tried and all working good with press not a problem.So there is a problem with ink or printer I think I have asked cie for ICC but they have got funny with me a bit said that I don't really need ICC to print and do sublimation.No idea if I need to get new ink or what else to do.
Re: Something wrong
I do have to diffrent type of paper. one is from Ink Express sublimation shrapnels 120g ,other one is from CIE.When pressed image is exactly the same yellow on both papers.I I have changed ink ( I did get that with printer so it is second hand ) I have flushed heads as well.
Re: Something wrong
I can't understand why CIE would say you don't need an ICC profile for sub-printing with their inks and a Ricoh 3110 printer. I've always found communications with CIE to be excellent.jack73;135026 wrote:it is reading at 180 Celsius I have had delivered today some samples of dyes sub printed already tried and all working good with press not a problem.So there is a problem with ink or printer I think I have asked cie for ICC but they have got funny with me a bit said that I don't really need ICC to print and do sublimation.No idea if I need to get new ink or what else to do.
Saying that, since I use the same inks, paper and printer as you, I can PM you a link to download a CIE profile (for your MacOs) and see if that makes a difference. I don't print with Inkscape though so you'll have to find out how to use an ICC with that software.
The only other thing I can think of that may be causing your issue is that you haven't flushed the old inks right through and the new inks aren't reaching the print heads yet. It takes a LOT of ink to refill those ink lines.
- Has thanked: 13 times
- Been thanked: 12 times
Re: Something wrong
Is it Ink Express Subli Sharp paper? Are you saying the transfer print is yellow or only yellow is transferring?jack73;135027 wrote:I do have to diffrent type of paper. one is from Ink Express sublimation shrapnels 120g ,other one is from CIE.When pressed image is exactly the same yellow on both papers.I I have changed ink ( I did get that with printer so it is second hand ) I have flushed heads as well.
No matter what the paper is if it's just printing yellow the fault is with your printer. if the profile was wrong, settings wrong etc. it would still be colour, all be it the wrong colours. Just yellow leads me to thin CMK are blocked. Can you post pic of nozzle check.
if you had old non subli ink in that printer it all needs flushing out, you can';t just add carts and it will work through, it will take forever.
Other than the cotton t-shirt, what else have you tried pressing onto?
Re: Something wrong
[MENTION=9065]jack73[/MENTION] I have PM'd you with an ICC profile and instructions.
Re: Something wrong
Just to let you all know finally all is working how it’s should with all of your help sonone day we will have cold bear lol so there they are light not good and still need to learn a lot about it all how to place and all of that but getting there .
