pneumatic mug press
anniecov
Re: pneumatic mug press
Post by anniecov »
Here's a photo of the whole mug done at 180c for 180 seconds. Base pre-heated for 30 seconds. The base looks great it's the top corner that's rubbish.
vB_ID:3829
vB_ID:3829
MCB12
Post by MCB12 »
It's the same as yours, not sure i like it.......
What printer are you using?
anniecov
Post by anniecov »
Ricoh SG3110 with Sawgrass inks and JetStream paper.
MCB12
Post by MCB12 »
Are you printing using the PowerDriver or just straight from the printer. Your colours look really good, whereas my look faded. I can't figure out if should put the temp up and heat for longer???????
anniecov
Post by anniecov »
PowerDriver.
Where do you print from? We print out of Photoshop letting PowerDriver manage the colours. Make sure it's set to "perceptual" rather than "relative".
vB_ID:3830
vB_ID:3830
MCB12
Post by MCB12 »
Thank you! PowerDriver successfully installed and colours looking better.
The only thing now is, how to print more than 1 image per sheet - anyone?
Using PSE13
Morele
We use specially sized mug paper which means you don't waste any from A4 paper if only doing one and makes whole process much quicker when doing lots. Olly
MCB12
Post by MCB12 »
Can you tell me which paper, and where you got it from?
I can't get my head around PSE13 and it not allowing you to print the same image more than once?????
We use the mug paper from BMS (printerowners.co.uk) and have a view of this video which should tell you how to set printer for paper sizes other than A4 https://www.youtube.com/watch?v=HXxMtcq0aW8
anniecov
Post by anniecov »
MCB12;108573 wrote:Thank you! PowerDriver successfully installed and colours looking better.
Using PSE13
Morele
If you look at my image of print settings, it pretty much shows you how to put 3 on an A4 sheet.
