CorelDraw X3 - contour cut with a border
Any OS, software in here.
Re: CorelDraw X3 - contour cut with a border
the new/er method is more accurate and more inline with the industry
Totally agree, it was just very frustrating having repeat customers and not being able to recreate what they had originally (when exported in X3). X5 is great in my opinion and much much better
AlanD
Post by AlanD »
socialgiraffe;97022 wrote:Totally agree, it was just very frustrating having repeat customers and not being able to recreate what they had originally (when exported in X3). X5 is great in my opinion and much much better
X6 and X7 has built on that although the earlier versions are more than capable. If your work involves taking alot of files from others the improved import filters are great but even those may cause problems if you do not have a font expecially with pdf in that instance I use Pstill from www.pstill.com it does an excellent job of converting any embedded fonts into curves and producing another pdf which will import into virtually anything. Text is not editable but you do have the letter shapes - sorts out transparency issues as well.
