installing sunangel printers????
soulclaimed
Re: installing sunangel printers????
Post by soulclaimed »
how do your sunangel transfers feel on a tshirt arfermo as mentioned before mine have a noticeable edge and texture compared to tmt papers im wondering if its the thickness of the toner laid down or if its that im not pressing heavy enough or if the tmt papers are just generally better
KathG
Post by KathG »
Thanks AfterMo, I think you are correct. I will put the pressure up to its highest on my next attempt. For me the paper sticking I think was user error as I grabbed a piece of A3 printer paper instead of my Teflon sheet and gave it another 30 seconds which was probably to long.
Which WOW paper are you using. 7.2 or 7.7 ?
Thank you to you and Tony for any help and advice given, much appreciated.
Kath G.
Cheers
Kath
ArferMo
Post by ArferMo »
wow 7.7............
KathG
Post by KathG »
Thanks again AfterMo,
Sorry for all the questions, but do you print on the WoW 7.7 exactly like you do with the SUnAngel papers.
just found a Compatibility chart on the TMT .com site but cannot seem to post it from my iPad. Will post it when I'm on my iMac
Kath G
Cheers
Kath
KathG
Post by KathG »
vB_ID:3365
vB_ID:3365
Here is the compatibility chart for TMT for our printers
Kath G
Cheers
Kath
ArferMo
Post by ArferMo »
Q. "do you print on the WoW 7.7 exactly like you do with the SUnAngel papers"
A. No.
With sunangel paper I only use the white where I want to see white on the finished image, not as a total mask behind the whole of the image, even if its yellow on a black garment, there is no need to back it with white toner.
KathG
Post by KathG »
AfterMo, thanks once again. I appreciate getting your help with this. Just need to decide whether to buy the SunAngel colour as I don't think I can tell how good/bad �� it is with just the White printer.
KathG
Cheers
Kath
soulclaimed
They refused as it "needs" wow pad and they only want the papers used with their printer
KathG
Post by KathG »
WoW no pun intended....I was going to ask for a sample. Don't really want to spend all that money if I end up not liking it.
Kath G
Cheers
Kath
KathG
Post by KathG »
Just thinking, it's a bit strange when their compatibility charts says it works with the OKI 321......oh well their loss
Kath G
Cheers
Kath
