Which Sub Paper to use?
adamctid
Re: Which Sub Paper to use?
Post by adamctid »
I'm making mugs and phone cases using subright transfer paper, everything I do takes a lot longer than I have been told it would, the manufacturer of my 3d vacuum heat press says its due to the paper not being good enough.
Does this sound likely to be the reason please?
Which paper should I be trying if this is the case.
Thanks,
Paper will make a huge difference. Xpres do a very cheap paper which is excellent, TruePix is the paper of choice for most but costs a little more :-) iSub are also supplying a new paper (see banner) which sounds excellent but I'm yet to try it myself.
adamctid
Post by adamctid »
Thank you I'll try one of them.
