who sells the best mugs ...
phoenixalpha
Re: who sells the best mugs ...
Post by phoenixalpha »
and in the Red Corner... BMS... and in the Blue Corner... Coralgraph....
*fight*
James990
Post by James990 »
ANd the blue corner, for me, wins every time!
James
phoenixalpha
Have to disagree there... BMS for me. Its horses for courses. Whatever works for you, stick with it.
Raja is first supplier for us, but they only work out as good pricing if you're buying by the pallet load.
samoht146
Post by samoht146 »
I have used them all and Coralgraph works for me-there are many who keep resurfing with terrible mugs that fade and keep changing there names.
mrs maggot
Post by mrs maggot »
we initially used a box from CG and as normal it is only when you try other suppliers, you realise that the mug makes all the difference, we use Listawood, BMS and more recently Isub Supplies (they are in the same town as me so i can collect) all are in a different league to the ones from CG - unless they have changed vastly in the past 3/4 years
jennywren
Post by jennywren »
Andrew;99587 wrote:I am with Paul on this, sounds like you have more issue's than the mug. Used many Coralgraph mugs over the years and as good as most suppliers out there. Most people have their own preferences. One of the preferred companies on here happens to be the only company where I have sent the mugs back as unusable. Also, different mugs require a slightly different method and adapting to. Sounds like your colours fading etc are more to do not printing them correctly or your set-up not being quite right.
I was going to say the same. I use them and find their mugs quite good. Maybe just check your set up
samoht146
Post by samoht146 »
I'am with you on that one James,EXACTLY the same thing happened to me last Xmas CG were low on stock so I had to go elsewhere,come Feb/March all I done was replace mugs as they started fading cost me a fortune but I learned a lesson from it!
James990
Post by James990 »
If I see them advertising again I will put thir name on here so you can all steer clear of them
Tonyphotodog
Post by Tonyphotodog »
Just tried to order mugs from BMS but they are out of stock at the mo.
