3d sub dont want to do a full load
3D Sublimation
ushi
Re: 3d sub dont want to do a full load
Post by ushi »
by preheat i mean let the oven keep heating for about 10-20mins after it reach the temp you want (200 in your case).
Andysam26467
Post by Andysam26467 »
I too had this problem and the problem was I wasn't let the oven heat up enough. As soon as it reached temperature I started the timer. Us hi is right, you need to let the oven stay at temperature for at least 10-15 mins before putting in the mugs. Then let the over reach temp again and start the timer. Once I did this they have been perfect every time .
Andy
try mugs in normal position. bottoms down. if they are all up heating my not be able to circulate properly.
