PVC
confidential
Re: PVC
Post by confidential »
Just a quickie, can I sublimate on PVC material - i.e. fake leather?
Andrew
Re: PVC
Post by Andrew »
Propably not if it is PVC. Some rubberised materials perhaps but it comes down to heat and then the polyester content or finish to hold the print. Most materials of this type will melt before allowing a decent print if it did have a receptive surface.
confidential
Re: PVC
Yeah I thought the melting may have been a problem, any other material suggestions anyone?
Andrew
Re: PVC
Post by Andrew »
Hi John,
The first video shows the print onto a material flap that is stitched onto the faux leather. These have been about for a while and are available through quite a few suppliers over here. Xpres have a decent range of the leather look type. The second isn't sublimation but Magic Touch transfer paper. Martin at BMS could probably fill you in on that stuff.
Good luck,
Andrew
confidential
Re: PVC
I've been looking into getting a laser printer for the cotton aspect of things, so I guess I can use it on leather and maybe pvc.
Martin, is the transfer paper available in A3 or A3+
Re: PVC
There are 2 types of TMT Paper for what you want to do - TTC for textile (light coloured cotton garments) and CPM for hard surface products (e.g. leather, ceramics). TMT page is http://www.themagictouch.co.uk/transfer/index.htm and it comes in A4 and A3. We can beat TMT advertised prices for their papers.
confidential
Re: PVC
What A3 lasers are compatible with the transfers paper, any recommendations?
Re: PVC
There is an Oki A3 which is recommended by TMT, but I can't recall the model number right now.
