Hip Flask in oven?
JMugs
Has thanked: 9 times
Re: Hip Flask in oven?
Post by JMugs »
Anybody printed hip flasks in an oven?
Had a tentative inquiry so wondering about times.
Janners
Andrew
Post by Andrew »
Trialled a few times and works well enough. As long as wrap gives good pressure like on the mugs you can get good coverage. Time is quicker than mugs as well. Similar temp.
JMugs
Post by JMugs »
Hi Andrew what sort of time are we talking about? If I use the oven for mugs I am 210 degrees for 14 minutes, what sort of drop in time am I looking at 1/2, 2/3 etc.
Janners
Andrew
Post by Andrew »
Probably 5 or 6 minutes. Trial and error.
JMugs
Post by JMugs »
Cheers Andrew,
Gives me a ball park area to start.
Janners.
Andrew
Post by Andrew »
No problem. Metal thermal mugs etc takes around a third of ceramics in a press so guess it works roughly the same. Getting the wrap right is key on the hip flask.
