Ricoh warranty
Re: Ricoh warranty
I don't see why not but bear in mind the large amount of ink that charges into the lines upon install.
Re: Ricoh warranty
Everyone will be pleased to know that all suppliers will be offering a 2 year warranty on the Sawgrass printers shortlyJustin;98720 wrote:They work perfectly well with subli inks in, it's very much like Epson saying you can't use any other third party inks in their machines when you know well that they often work just as well if not better
Did you have much ink left? Might be better to bite the bullet and just buy a new setup. That extra year from iSub on their printers is a big bonus.
Re: Ricoh warranty
The error SC 28113 is related to an ink supply time out error.india;98688 wrote:I'm not happy about this. Would never buy another Ricoh Does anyone actually know wat the error code scanner 28113 means ?
Re: Ricoh warranty
Everyone except the OP (India)bms;98727 wrote:Everyone will be pleased to know that all suppliers will be offering a 2 year warranty on the Sawgrass printers shortly
Re: Ricoh warranty
Is there any way I can fix it?bms;98728 wrote:The error SC 28113 is related to an ink supply time out error.
soulclaimed
Re: Ricoh warranty
Google shows many different people saying many different things try removing ink and all paper check for paper jams and reinstall tray first and if error changes then install inks is one thing it says. Search google with the error code and the word fixya you'll find a lot of this on fixya forums
Re: Ricoh warranty
As a last resort you can do a factory reset and install cartridges from new. This will completely reprime the tubes and use quite a bit of ink.india;98732 wrote:Is there any way I can fix it?
