Hi all,
I was just about to print and 'cook' my first money box and I stopped ..............
I was just going to use the template I normally use for mugs but obviously noticed that there will be more room due to not having a handle on it.
So I paused for a moment and printed off a blank template which I then wrapped around the money box to check for size and compatibility.
I noticed that the money box is slightly larger than a mug (so I can't get a full wrap around in the press) so I presumed that the 'best option' would be to only do the front of the money box.
Then I looked at e-bay (often a good source to see what's on the market) to find that there are some money boxes that have an image on the front and text on the rear.
- How do others do their money boxes? one sided or two sided?
- And, would it be possible to cook the image on the front - cool it then cook the text on the rear to create a full wrap around look? (or will the image from the first transfer run/burn during the second process?).
Adam
Money boxes
Re: Money boxes
Re: Money boxes
Another way of looking at this is an image on the right hand side and text on the left - that way you can get both pressed at once in a mug press.an image on the front and text on the rear
Or... press one picture on one side, remove and print another picture/ text on the otherside. The first image won't change - just cover with a sheet of silicon to prevent and cross contamination from the mug blanket to the printed face.
Re: Money boxes
You know what Martin,
I think I was just confusing the matter! I just rotated the template around slightly and as you say you can print the front and rear together in one sitting!
................. it's been a long day!
Thank you
Thank you
Re: Money boxes
Ahhh, but it is the front and rear or the left and right???you can print the front and rear together in one sitting
whitesquizzel
Re: Money boxes
Is a Silicon Sheet OK for protecting the first print or do you mean the silicon wraps?
Re: Money boxes
Silicon sheets will be fine - just like the grease proof paper materialIs a Silicon Sheet OK for protecting the first print or do you mean the silicon wraps?
