Hi I am looking for a bit of help, I have some mug designs with cutouts for photos but unsure how to place them in?
I recall seeing a video last week somewhere but cannot find it now.
Any help is greatly appreciated.
Thank You
Meant to add I am using coral draw 6
Coral Draw
Re: Coral Draw
If you have set up the cut outs with a transparent fill then you can simply send the photograph to the back of the page...
Re: Coral Draw
Powerclip is the easiest way to place a photo into a given shape, be aware that the is a setting so that it can auto centre to the clip shape or you can set the photo position to the clip shape. It is easy to use this feature though, found under effects in Draw versions upto X7 where it moved to objects (don't ask my why)
