Teflon sheet
FBW
Re: Teflon sheet
Post by FBW »
Im expecting delivery of a flat bed heat press tomorrow
Initially it is just for coasters
Ive noticed different suggestions - some say put in a teflon sheet on the top - others say just plain paper
Will plain paper do or should I wait until I get teflon in?
Re: Teflon sheet
I use A3 sheets from Xpres, huge pack lasts forever and always worked a treat.
http://www.xpres.co.uk/p-7645-silicone- ... heets.aspx
FBW
Re: Teflon sheet
Post by FBW »
Thanks Justin
Quinsfan
Re: Teflon sheet
Post by Quinsfan »
I use a roll of baking paper just cut to size and reuse.
FBW
Re: Teflon sheet
Post by FBW »
Quinsfan;95974 wrote:I use a roll of baking paper just cut to size and reuse.
oh bugger...just ordered the above. never thought of that.
Re: Teflon sheet
Xpres not the cheapest option but tried, tested and cut to size :-)
Did you just order online? 10% off as A Premium Member if you phone through to place your order!
FBW
Re: Teflon sheet
Post by FBW »
Justin;95980 wrote:Xpres not the cheapest option but tried, tested and cut to size :-)
Oh another bugger! :) :)
ah well £2.50 wont break me ...just yet. Thanks for the reminder though
Bob @ Prestige
Re: Teflon sheet
Post by Bob @ Prestige »
has anyone used the backing paper from sign vinyl? this is silicone on one side, just wondering as I have copious amounts of this available
Bob
Re: Teflon sheet
baking paper from wilko :)
always getting few rolls every time i am there.
also VERY heavy duty teflon sheet/ oven liner is available now in ALDI. so if you have one local to you, then is worth to grab few. very thick and £2 per sheet :)
https://www.aldi.co.uk/en/specialbuys/s ... n-liner-5/
Bob @ Prestige
Re: Teflon sheet
Many thanks for the info Paul
Bob
