Fading at the base of mugs
Jollyware
Re: Fading at the base of mugs
Post by Jollyware »
Hi again,
Can any one tell me why this happens please.
vB_ID:3217
vB_ID:3217
AlanD
Post by AlanD »
I was getting fading at the base and eventually tracked it down to the mugs. First box I had were perfect - next 2 boxes faded at base, 2 more boxes from a different supplier were fine. Put a straight edge on the mug side, does the mug taper towards the base? if so even pre-heating the mug base may not make a difference. It has become clear to me that not all mugs are the same. Doesn't matter what the suppliers claim regarding the coating if the mug isn't straight you will struggle.
Perhaps we should start a campaign to get mugs rated for straightness as well as dishwasher durability, I bet mugs and ink are being wasted by the skip load.
bigj2552
Post by bigj2552 »
dont be so quick to blame the mugs here.....
your mug press blanket could have a cold spot at one end....
set your time for your mug press, add another 10sec onto that time....
then half way through sublimation, turn the mug around and continue heating...
then come back and see us ;-) :wink:
Jollyware
Post by Jollyware »
bigj2552;96340 wrote:dont be so quick to blame the mugs here.....
Cheers, will give that a try when I next do one .
AlanD
Post by AlanD »
When I had similar issues I printed the mugs the other way round - same problem always faded at the base, top was fine
DANNYD
Post by DANNYD »
Might be a taper at the bottom of the mug, had problems with the Isub ones i got, testing my coralgraph ones at the moment, seem a lot better, Just out of curiosity about sticking the mug in at 100 degrees, is that the same for all mug presses?
JMugs
Has thanked: 9 times
Post by JMugs »
Anything to do with sublimation is subjective, every factor can have an effect.
Starting at 100 degrees works for my DF1 press, my xpres presses are different.
Andrew
Post by Andrew »
It does look like a straightforward not enough heat to the base scenario but what is the tiny purpleish band at the bottom? Is that from the transfer? Looks strange.
ArtyGamer
Post by ArtyGamer »
If it's at the base, and the problem is STILL at the base when you turn the mug around to transfer, it means that the mug itself is already too cold and not reaching the temperature for the sublimation process to complete. Had the same issue at the start when I was using my vacuum press so I started to turn the mug upside down to allow the heat to fill the mug and heat the base up. They've all been perfect since. In the case of an actual mug press... I dunno... you could perhaps heat the mug up first by sitting the base in some boiling water for thirty seconds, then dry it off completely before pressing it.
Anything's worth a try, at this stage.
rossdv8
Post by rossdv8 »
I solved my problem with fading by getting a cheap Chinese press with the thin horizontal elephant. The press makes up for any taper. There are good quality presses that look like they do the same, I think maybe the DK3 is one of them.
Since I changed presses I have had no problem with my bottom fading.
