Oki C 511DN & Forever Laser Dark
raydavies
Re: Oki C 511DN & Forever Laser Dark
Post by raydavies »
Has anyone tried the above combination? I understand a lot depends on the "Fusing Temperature" So far I've been unable to find out what the temp is for the C511DN. It seems the paper is good for below 350 Degrees.
Any help would be appreciated.
Ray
Pretty sure mines the 511 and it works a treat with this paper. I've only done a few darks, the Xpres onto white is brilliant.
raydavies
Post by raydavies »
Thanks Justin that's good to know, can you recall the settings you use?
Many thanks,
Ray
Yes, it is the 511dn :-) Settings pretty much as per instructions, having the Adkins heavy pressure can be useful.
