print settings
Any OS, software in here.
Gtphotos
Re: print settings
Post by Gtphotos »
sorry should have said for each of the items, crop, sharpen, profile, cut guides, ect
Re: print settings
DANNYD;93453 wrote:Anyone on a mac tell me if there is any settings like in the Powerdriver for changing substrates?
All the PowerDriver is doing is selecting the appropriate print settings,including the ICC profile for what you're printing ... do Sawgrass not have a range of ICCs available for different substrates, or is there a way of extracting the ICCs from PowerDriver?
Otherwise, you may want to consider getting custom ICC profile made for the different substrates you use, or ideally buying your own profiling kit will pay for itself if this was the route you wanted to go down.
dougbraz
Re: print settings
Post by dougbraz »
Gtphotos : interesting.
I have saved templates in PS CS CC as I use quite a few layers per print so LR is not really an option (no point saving into LR from PS and then printing if you can do it straight). Maaybe I'll give it a whirl with simpler non layered images - I must confess I have never printed from LR yet.
dougbraz
Re: print settings
Post by dougbraz »
pisquee;93460 wrote: do Sawgrass not have a range of ICCs available for different substrates?
I am looking forward to this answer as well, as I print on cloth, ceramic and aluminium, all with the same ICC profile from Condé.
