anyone else having probs with these cases ??
ours have started to sag in middle when cooling, that then makes the cases springy at the side of the dummy phone case, and obviously it dont fit....
we have tried the cooling jig and slightly bending the case till it slightly arch's in the middle....yep, that cures that, but the dam phone will not fit after cooling...
have tried it on cooling jig with the phone on the case as its cooling - nope....still sags in middle and sides seem to creep upward
have tried cooling the case on the phone its self....nope....
im beginning to think we got a duff batch of chinese cases here ;-(
think i will need to see what UK seller sells them to see if its us thats doing something wrong, or the cases are duff :rolleyes:
is it just us ??
have tried all time s n temps...currently cooking at 190c for 100sec on the mini 3d machines for all our cases/mugs ect....they coming out perfect print...just the dam things will not fit the dummy phone....and this is the 2nd dummy phone just in case it was the phone at fault
3d iphone 5c cases
Scotty@BMS
Re: 3d iphone 5c cases
When you're cooling on the dummy phone are you popping it on and leaving it to cool slowly or dropping it into cold water? If its the former I'd try the latter. The shock of the cold may well arrest the warping seemingly resultant from a gradual cool...
solved the prob scottie boyScotty@BMS;92394 wrote:When you're cooling on the dummy phone are you popping it on and leaving it to cool slowly or dropping it into cold water? If its the former I'd try the latter. The shock of the cold may well arrest the warping seemingly resultant from a gradual cool...
3 dummy iphone cases i bought from 3 diff sellers on ebay...they were iphone 5s cases...
went n got real, but broken iphone 5c from ebay.....no saggy middles now.....help when one uses the right case to cool the printed cases lol
dunno how i never noticed it before tbh
