Sublimation placemats
colmac01
Re: Sublimation placemats
Post by colmac01 »
I am just trying to print some placemats. The image is black and white but the blacks are coming out mottled. Has anybody got any suggestions? Thanks in advance.
:confused:
200C -60C is your time and temp?
colmac01
Post by colmac01 »
That is correct! Any suggestions. Was going to try 70 seconds but worried about ink burn.
Could be moisture, try a pre heat.
colmac01
Post by colmac01 »
How long for? 10 seconds?
i would go for 70sec.
colmac01
Post by colmac01 »
Cheers Paul, would you not bother with a pre heat?
i didn't pre heat. bu i pressed my with 190C for 60sec. with heavy pressure.
here is the video and results. from 8min8sec http://youtu.be/ZxwO4MRiZ-w?t=8m9s[/video]
colmac01
Post by colmac01 »
Tried again this morning and am still getting a mottled effect in the middle of the place mats. I am giving up with them now. Wasted too much time and money on them now!!! Yet coasters are printing fine.
coasters are smaller, so heat may be more even. is it possible you have a big cold spot in the middle?
