Data sheet required for aluminium
Niki MM
Re: Data sheet required for aluminium
Post by Niki MM »
My husbands employer is interested in what i do and would like to place an order. However its critical they have a Data sheet with what the material is made out of exactly once sublimated.
I've emailed a couple of companies but so far all I've received in instructions on how to print :( I already know that lol
If anyone could help or point me in the right direction I would be extremely thankful.
All the best
Nic
Ask_Alan
Post by Ask_Alan »
Ask the coated Aluminium material supplier for a MSDS (Material Safety Data Sheet). The same from Sawgrass, I assume you are using Sawgrass inks. Searching the Sawgrass Site for MSDS will turn up several documents.
I suspect no one has done an analysis of the result of sublimating with dispersion dyes into polyester coated aluminium.
alan
sublimetals_nicci
Post by sublimetals_nicci »
Hi Niki
Sorry for the delay - I was waiting for the data sheet from my suppliers, I have it now, so have sent you an email
Thanks Nicci:smile:
Users browsing this forum: Majestic-12 [Bot] and 2 guests
