Display boxes for coasters
Re: Display boxes for coasters
Hi, can anyone help? I need boxes for a set of 4 coasters, can anyone suggest a supplier.
Coli
Coli
- UK Printed Mugs
Hi Coli. I am having exactly the same problem in trying to find a suitable coaster box (want clear PVC) that will fit 4 coasters and will be ok for Royal Mail large letter. I have found these though which are very nice but are maybe a little too expensive: http://www.tinyboxcompany.co.uk/p/89470 ... ba2wh.html
Thank you UK printed mugs, I will have a look. Pisquee the coasters are 90mm x 90mm.
Thanks both Colin
Thanks both Colin
Hi UK Printed Mugs. Just looked at the boxes, they look great but a little too expensive. Thanks anyway!
- UK Printed Mugs
Yes I agrees. I will continue to look as well and so perhaps if either of us find something cheaper then post it here. Olly
How thick are the coasters, including feet/backing, i.e. how deep does the box need to be?
- Has thanked: 11 times
- Been thanked: 9 times
I found some great card boxes on eBay a couple of years back, they fit 4 x 90mm coasters and a slotted holder (at a squeeze!) If I remember to dig one out I'll upload pics, perhaps not what you're after though? I just use them for presentation as they're gift boxes, not really for mailing.
So four of them stacked up would be 60mm, so plus the box itself and packaging, you're going to be over the large letter rate (25mm) - in fact, even two stacked will put you over the large letter rate.
Also, the 10cm Tiny Box Co (linked to above) square box is only 17mm deep, so only big enough for one coaster.
However, this one is 45mm deep and you may get away with more in, and only 93mm width, so a better fit for 90mm coasters
http://www.tinyboxcompany.co.uk/p/73323 ... aiv45.html
