Hi guys.I need to print the sign oboe the shop but not sure where to find correct sheet of metal or board for it.
Anybody knows where i can buy board correct for this job? Sign will be made out of vinyl.
thank you in advance.
paul
sign boards
Re: sign boards
Paul you need what is called DiBond or Aluminium Composite. You normally have to buy the sheet and they will cut it down for you. I get mine from here http://www.perspex.co.uk/
they are not the cheapest but are on my doorstep. They have a gloss and matt side.
Re: sign boards
Thank You! Thank You! Thank You! Thank You!
DiBond is what i need! thanks again!
Re: sign boards
My main job is as a sign manufacturer / fitter. If you any other help feel free to PM me.
Re: sign boards
Yes, I have been using DiBond, be aware that DiBond is an actual manufacturer but a lot of people call any laminated aluminium/composite board 'DiBond'.
Re: sign boards
I use trent plastics for any Sign boards etc , they sell most of their stuff on Ebay
Mimaki CG60-st cutter , Ricoh 3110 sub printer , OKi laser , Epson inkjet , 2x heat press , mug press , cap press, Flexisign pro and coreldraw X6..............and learning ...........
and now a Roland SP-300v Versacamm !!!!!!
