Extending wi-fi distances
PC or Mac, anything Hardware in here.
NikGrey
Re: Extending wi-fi distances
Post by NikGrey »
What you need is an Amateur Radio enthusiast as One of your forum members, it might also help if One of his past occupations was being a Sound Engineer as he would know the theory of this kind of venture..lol.
Yes, you can do it - you just need to buy or build a 'Yagi' antenna (Thats what a TV antenna is - Directional).
You do need another to receive of course - the problem is it MUST BE in the 'Line of Sight' to work.
There will be commercial offerings.
You see those little 'Wi Spire' dishes around - thats what they are doing, all pointing to the Spire where the transmitting antenna is situated.
Ah, I was a sound engineer too, before I quit and did this instead!
NikGrey
Post by NikGrey »
That's Three people I have other things in common with on this forum - You (Sound Engineer), Simon (DJ) and Arthur (Welder/Plater) :)
Here's the sort of thing I would be undertaking if I wanted to extend Wi-Fi over a distance.
As it stands I have another router in my workshop which has the DD-Wrt firmware on it which I use as a WiFi bridge - just picks up the original signal from my No1 router in the house and re-broadcasts it, same log in details and ID (SSID) as the main router so people dont have problems moving between the different signals - seamless :)
Has thanked: 13 times
Been thanked: 12 times
many thanks for the info guys, lots of reading to do :-)
I found this which looked interesting http://www.ebay.com/itm/2-MILE-Long-Ran ... 0471510612
but at these prices I might well be better looking at a phone line and broadband connection! lol. Not so much fun though ;-)
The chap doesn't seem in a rush to get the unit cleared and ready to rent which is a shame as it's perfect so I'm looking at other options......internet won't be a problem either.
That gadget does look interesting Justin - do you need one at each end of the connection, or is everything in the kit all you need?
Also, what's the legalities for the UK in terms of using a transmitter of that strength in that freq band?
DS Designs
Post by DS Designs »
And I'm an A class licenced radio amateur lol.....forgot most of the theory though to be honest, but yes, a Yagi antenna may be the best idea being directional
NikGrey
Post by NikGrey »
According to the FCC rules this exceeds our permitted ERP (Effective radiated power) as it has a 20dbi (gain) antenna.
The unit has a power of 1000mW (1 watt) - we are allowed 4 watts but the gain of the antenna (every 6db doubles the radiated power) will push the radiated power WELL above our allowed 4 watts.
I'm a 2EO at the moment (so went through all of the theory for that test) am hoping to take my 'M' class at the end of this year but to be honest I dont think I will have the time as it is a full weeks course.
2EO NGR
logobear
Post by logobear »
Have you looked on instructables? - I can recall seeing many diy dish based range extenders
