Water Bottles 70mm ?
NikGrey
Re: Water Bottles 70mm ?
Post by NikGrey »
ok my Water Bottles are here from Listawood (Aluminium, white - 600ml) and I intend to use a Mouse Mat as the spacer as the sheet above is too thick (Bottle is 72mm).
What times and temps are you using the these - Justin, you said you have done thousands, as you have the same press as me I guess you would be best to answer this ?
I press for 50 seconds at 200 degrees and perfect results every time (think I did 1500 ish last month). These were white 400ml ali bottles from Listawood using a Genie (Listawood) Heat press and the correct blanket.
If you are using a mouse mat as a spacer I think you are going to have to up everything considerably and be prepared to spunk quite a few before you get it right as the heat absorption is probably quite high in a mat.
Good luck
NikGrey
Post by NikGrey »
"1500ish" - with that amount I'm not surprised you have the proper blanket.
I have 9 spare I can Spunk..lol.
Ah, just discovered its the 'Porcelain' blanket that's needed for these bottles - that will take most of the profit from this first run.
They were for Katy Perry's tour.
Sold really really well at £15.00 a pop :eek:
NikGrey
Post by NikGrey »
Can hardly see across the room for the 'Rubber' smoke..
Well, this is a journey :) I had to cut a 3mm mouse mat to the correct 120mm width and use a piece of Teflon sheet on the rubber bit..
I'm at 210c and 105 secs at the mo.. its fun though.
Quinsfan
Post by Quinsfan »
Nik
I know that this doesn't really help you personally but I thought this may help others.
I have done these in my halogen oven for 12mins at 200 degrees. I can get 3 in at a time. I use a 3mm silicon baking sheet cut to size. I then use jubilee banding to hold it all in place. I know most people on here have mug presses but I find an oven a lot more convenient and there is no mucking about with blankets or heating elements.
Wrap and go !
I will add a photo later. I am off out for the evening.
NikGrey
Post by NikGrey »
[ATTACH=CONFIG]2871[/ATTACH]
215c for 105 secs - design on both sides.
vB_ID:2871
vB_ID:2871
NikGrey
Post by NikGrey »
Looks like I am going to get away with not buying a smaller blanket BUT I need to do something about this Mouse Mat as it will not last much longer.
Is it a 'Silicone Sheet' I need - it needs to be 3mm.
Is there any specific spec I need for this sheet?
Quinsfan
Post by Quinsfan »
http://www.ebay.co.uk/itm/BRAND-NEW-SIL ... 4897.l4275
Found this one but any local kitchen shop large supermarket should have something similar.
NikGrey
Post by NikGrey »
That's perfect, I was finding Silicone sheets good up to 200c.. I need 215 so these baking sheets are just the ticket :)
It just so happens that my client is a commercial baker :)
