been asked if I could do these type of things but at present im only
working with an craft robo cutter
can someone recommend a good cutter and software to do this
type of stuff
[ATTACH=CONFIG]2826[/ATTACH][ATTACH=CONFIG]2827[/ATTACH][ATTACH=CONFIG]2828[/ATTACH][ATTACH=CONFIG]2829[/ATTACH][ATTACH=CONFIG]2830[/ATTACH][ATTACH=CONFIG]2831[/ATTACH]
looking some recomondations
Re: looking some recomondations
- vB_ID:2831
- 525558_10151877301267334_1707916616_n.jpg (59.04 KiB) Viewed 164 times
- vB_ID:2830
- 381675_254866254576786_311387192_n.jpg (63.85 KiB) Viewed 164 times
- vB_ID:2829
- 180267_10151631888177334_936738400_n.jpg (86.39 KiB) Viewed 164 times
- vB_ID:2828
- 601926_10151631891072334_761516793_n.jpg (92.53 KiB) Viewed 164 times
- vB_ID:2827
- 397159_3425502806437_503990947_n.jpg (45.3 KiB) Viewed 164 times
- vB_ID:2826
- 418937_10150551982352334_844463873_n.jpg (28.87 KiB) Viewed 164 times
Silhouette would probably manage it if you're on a budget. I have the Graphtec CE6000-60 as well which is a fabulous machine but not cheap.
George I would suggest some could be cut on something like a Graphtec CE5000 or the newer 6000 model. Others would need printing on something like a Versacamm.
I never heard back from you for the images you contacted me about...hope you got sorted OK.
roger the person that wanted the stuff done changed her mind but whats new in life these days looking stuff get you to work on them and then say I will leave it till later lol
