Ghosting - Double Image nightmare
kasoaparte
Re: Ghosting - Double Image nightmare
Post by kasoaparte »
Hi guys
Im back with a brand new problem i cannot fiX...
Two months ago i started sublimating flip flops with my chinese flat clamshell heat press. Everything was perfect that time, 90% of flip-flops with no ghosting using only two pieces of thermal tape on sides. 200º and 60 sec, nothing else.
We are producing flip-flops again but we are having serious problems with ghosting... We are using same temperature, thermal tape, pressure.. but 80% of stuff is useless because this ghosting.
So we are paying attention to things we never watched before... Heating plate moves a little ( seller says its normal, they sent us a video of producing stuff and their heat plates moves too ), we are using glue spray, we have try other timing-temp settings ( 180º & 90sec - 165º & 120sec )... But still having problems
Some things have changed; like temperature: in this side of Spain now is 10degrees hotter than two months ago...
Any ideas? we are really frustrated and lost about this.
We can attach videos or pictures if somebody asks.
Thanks a lot and regards from Spain
Find our atwork at www.pnitas.es
When you open up the press, the pressure change/vacuum effect can lift the paper from the substrate, and ghosting can be the result. Using spray adhesive can help (we use 3M 75) and very gently/slowly opening up the press can also help.
kasoaparte
Hi again
pisquee: We have been using 505 spray from the beginning, and we can say is good enough for this.
The thing is that with thins stuff like iphone cases is fine, but with flip flops is a nightmare.
We try to do it really slow when the press opens up; we have tried different pressures... nothing works
And one important thing: Ghosting always appears in the same part of the flipflops.
Any ideas?
Maybe there isn't enough pressure during the actual pressing if it's the same area of the flipflops having the problem?
kasoaparte;88942 wrote:Hi guys
Can you confirm what you mean by "ghosting"? I assumed this to be something like a double image which would be caused by the paper lifting and repositioning when hot, but I'm wondering if this "ghosting" is something different. Can you explain or post a picture?
kasoaparte
Ey guys
Sorry, i was offline.
Finally i fixed the problem. It was about pressure.
Last time we made flipflops we use a medium pressure, but this time ( 2 months later and pretty much hotter ) we had to decrease the pressure and temperature and increase timing.
Everything is perfect now.
I suppose this kind of facts can be very important in sublimation process; pay attention guys!
Thanks to everyone that replied :-)
