Oki c511dn
Re: Oki c511dn
can someone tell me if this printer will work with TMT transfer papers or other good ones?
thanks.
Re: Oki c511dn
Couldn't get them to go through mine successfully Paul but Xpres papers worked a treat.
Re: Oki c511dn
are they any good from xpress?
Re: Oki c511dn
Excellent :-)
Re: Oki c511dn
thanks Justin!
windyash
Re: Oki c511dn
Post by windyash »
Only used xpres through mine but works all ok
Mimaki CG60-st cutter , Ricoh 3110 sub printer , OKi laser , Epson inkjet , 2x heat press , mug press , cap press, Flexisign pro and coreldraw X6..............and learning ...........
and now a Roland SP-300v Versacamm !!!!!!
Renniwano
Re: Oki c511dn
Post by Renniwano »
I have had Xpres and Yolo papers through mine..
Re: Oki c511dn
can you tell me bit more about them? are they 1 step process or two? can i print black garments? i know there is no white toner but there is some kind of mask paper part if i am correct?
Re: Oki c511dn
The only drawback I can see is not being able to print white.
Re: Oki c511dn
but can i have a white background from mask? or there is no white at all?
