Cloudy transfer
AZCanuck
Re: Cloudy transfer
Post by AZCanuck »
Skye, thanks for the link, I've watched several dye sub video's on youtube, but I hadn't seen that one. That my have been the problem right there!
Paul, there isn't any tag or anything on them, but I'm sure they're for ink jet because I bought them with my printer.
Re: Cloudy transfer
where from??
I remember that i had same coasters before and similar problem.
they did transferred but there was no pop in colours and they looked washed out. i can remember hat times and temps i used as it was looooong time a go.
Scotty@BMS
Re: Cloudy transfer
Post by Scotty@BMS »
Is there a high gloss, shiny finish or are they matte? The later would suggest laser transfer coasters as Paul has said. If they are high gloss, then I'd pre press then for 45-ish seconds and see how much moisture comes out of them.
Re: Cloudy transfer
Yes scott, mycoasters was matte.
AZCanuck
Re: Cloudy transfer
Post by AZCanuck »
These are high gloss. I'm going to try again today & let you know what happens.
AZCanuck
Re: Cloudy transfer
Post by AZCanuck »
Well people, problem solved! It must have been the time, I think it was approx. double what it should have been.
This set turned out beautiful!
[ATTACH=CONFIG]2638[/ATTACH]
Thanks for all your input, it was very much appreciated!!
vB_ID:2638
vB_ID:2638
Coasters 2.jpg (60.71 KiB) Viewed 306 times
Frostee
Re: Cloudy transfer
Post by Frostee »
Glad to see things went better second time around. I'll be having my first bash at sublimating something tomorrow. Think I'll top up on the YouTube bids hehe
Graphtec CE6000-60, Sefa Rotex Pro Auto Open Swing, Galaxy Mug Press Pro, Epson P800 with sublimation inks, Ryonet Screen print setup
AZCanuck
Re: Cloudy transfer
Post by AZCanuck »
Frostee, if you're doing coasters, the tip on the clear plastic sheet is a dandy. I used 2 different coasters when I did mine & the first ones that screwed up didn't have the plastic on them, but the second ones did. I probably would have missed it if it hadn't been for Skye's help with the Youtube link! Just thought I would mention it FYI!
There's a wealth of info here! Thanks again for all of your support!
Frostee
Re: Cloudy transfer
Post by Frostee »
My stuff didn't arrive to couldn't play today :-( hoping for tomorrow ;-) so far I've only got mugs, jigsaws, mouse mats and a slate to have a test with
On confused about your last post though.would have missed what? Did you try print on the protective plastic?
AZCanuck
Re: Cloudy transfer
Post by AZCanuck »
No I didn't Frostee, but I probably would have if it wouldn't have been for Skye's link to the video. I just got lucky on the first ones I did because there wasn't any, but I wasn't looking for it either.
Have fun when your stuff arrives!
