Press wise. T-Shirts you really need a larger A3 size press, everything else you'd get away with an A4 size or similar. Obviously you'd need an A3 printer the n though so costs will rise significantly....unless you're going to print your Tees with vinyl?
Full set up. What to buy.
Re: Full set up. What to buy.
If you were to sit and work it out it would be pennies per coaster, tbh I wouldn't get hung up on it. My printer has been working for a year now on standard carts and is only now showing low ink on 3 out of 4....still life left in these anyway. I've done the equivalent of a few thousand coasters! Certainly been through 500+pages of subli paper
Your budget could get swallowed up quite quickly by the time you add up all those consumables...T shirts, phone covers etc. If your logo is going onto the T shirts, you could save a lot by making the design less than A4.
The Adkins range are very built, reliable and top quality. Take a look at the 15 x 15 and the 38cm x 30cm
http://www.xpres.co.uk/c-400-swing-presses.aspx
Add VAT onto those prices.
Ahhh right. Thats good news then was looking at the price on the sublijet inks and thought wow thats expensive. Lol
not that expensive after all then i guess.
So what sort of press am i looking at.
The only one i can see that will probs do all is the flat presses. Can anyone recommend one at all.
The budget is mainly for equiptment and coasters. I just want to make sure that what ever press i get that it can cope with other products just in case. Gotta think out of the box so to speak.GoonerGary;86123 wrote:Your budget could get swallowed up quite quickly by the time you add up all those consumables...T shirts, phone covers etc. If your logo is going onto the T shirts, you could save a lot by making the design less than A4.
Thanks for the link. Looks like a nice machine.
This is their website:
http://www.aadkins.com/
Clam presses are normally used for T shirts and swing away for fragile items like coasters. I intend to put my designs onto coasters shortly, so I'm looking at glass and Unisub coasters for the best quality.
what is unisub and thanks for the link.GoonerGary;86127 wrote:This is their website:
Unisub is a brand of coasters...vibrant colours.
http://www.thetransferpress.co.uk/acata ... sters.html
http://unisub.net/ (a division of Universal Woods - hence the "Uni" in Kentucky http://universalwoods.com/)meldean;86131 wrote:what is unisub and thanks for the link.
Large manufacturer of coated products for sublimation printing. Considered to be higher quality than most blanks available.
Some products marketed under the UniSub brand, but they also produce Chromaluxe.
- Alastair@Xpres
Good Morning Meldean,
I can put together some recommendations for you if you would like?
We have all the equipment you may need from the small to the large so please feel free to email me or give me a call on
01332 858 369.
We sell the printers, heat presses and high quality blank products from small to large.
If you are nearby you can pop in and see the equipment, just let me know so I can check availability.
Thanks, have a nice day.
01332 858 369.
[CENTER]Xpres Sublimation [/CENTER]
[CENTER]Powering Personalisation
http://www.xpres.co.uk/c-41-sublimation-xpres.aspx?
Email me on alastair.palethorpe@xpres.co.uk for equipment advice or quotes
