Method for printing on caps
Discuss other print methods.
windyash
Re: Method for printing on caps
Post by windyash »
Recently been asked about caps to go along with other clothing I sell , what methods work well ?
I was thinking normal clothing vinyl for one or two colour designs , is this ok?
Also can you use transfer paper on them? If so anyone recommend any that work ?
Just ordered some caps and a press so trial and error starts soon!!!
Mimaki CG60-st cutter , Ricoh 3110 sub printer , OKi laser , Epson inkjet , 2x heat press , mug press , cap press, Flexisign pro and coreldraw X6..............and learning ...........
and now a Roland SP-300v Versacamm !!!!!!
logobear
Post by logobear »
anything you use on t-shirts - all works the same - heat+pressure+time=result!
Only issue is REALLY stretching the cap over the clamp before pressure, - otherwise you can get a crease/fold in the middle of the print area = swearing!
