Mug turning black
Oaten
Re: Mug turning black
Post by Oaten »
Hi,
I'm having issues with printing it seems that the mugs are turning black and you can see the tape lines.
I print at 190c for 9mins.
Any tips?
[ATTACH=CONFIG]2517[/ATTACH]
vB_ID:2517
vB_ID:2517
NASH
Post by NASH »
9 minutes is way to long try from 3 minutes
FutureProject
Post by FutureProject »
are you using a blanket mug machine or an oven or some other way?
Oaten
Post by Oaten »
Really?!
I use a 3d sublimation oven not a mug press so does the same rule apply?
FutureProject
makes a lot of difference to your times / temperatures.. :)
Oaten
Post by Oaten »
So you think I should run them for 3mins?
Ask_Alan
Post by Ask_Alan »
if the polyester coating is going brown/ black its burning. Oven too hot? the temperature control in these is usually poor and inaccurate, turn the temp down perhaps 20 degrees and see.
Oaten
Post by Oaten »
So you all think the time is the main issue?
