Again, not the case. I personally use paper to demo 3D machines, but on the more commercial presses then film is often used. The standard Sawgrass inks in the SG3110 and the Epson 7890 print onto film (single A4, A3, roll) and sublimate in the commercial 3D machines without an issue and at low temps of 135-140.bigj2552;83964 wrote:from what i mind in the vid, the "low temp inks" are used solely with the film
but how can they use the SAME machine with 2 supposedly different inks ? - like i said earlier justin, cross contamination must come into play here no ?
just had wee chat to supplier...Hmmm
Re: just had wee chat to supplier...Hmmm
Received a full price list this morning, will discuss later
Dave271069
Justin;83989 wrote:Received a full price list this morning, will discuss later
oo exciting, i see a new thread and discussion coming on, pity we didnt have a live chat enabled forum thingy!
have to say, this is all way above my head... however I am trying to understand.Again, not the case. I personally use paper to demo 3D machines, but on the more commercial presses then film is often used. The standard Sawgrass inks in the SG3110 and the Epson 7890 print onto film (single A4, A3, roll) and sublimate in the commercial 3D machines without an issue and at low temps of 135-140.
Are you saying that you can sublimate at 140 degrees using sawgrass inks, or is this only in certain 3d machines?
Reason I ask is because I am mid way through a run of 1000 hi-vis bomber jackets that I am having to transfer instead of sublimate due to the stitching melting at the standard 180 degrees of sublimation.
They've put starter pack together for phone cases or mugs for example, prices for these seem to be $1000-$2000. They haven't detailed exactly what's in these packs, I'd expect a good selection of jigs, cooler, cases etc. Will try and get a break down.
Individual prices for moulds are around $50-$80, film is $60 for 50 sheets, spares (pump etc.) don't seem too bad.
Good work, thank you and look forward to seeing the breakdown. How much in GBP and also postage?
see here =michc;84009 wrote:Good work, thank you and look forward to seeing the breakdown. How much in GBP and also postage?
http://www.oanda.com/currency/converter/
Justin;84007 wrote:They've put starter pack together for phone cases or mugs for example, prices for these seem to be $1000-$2000. They haven't detailed exactly what's in these packs, I'd expect a good selection of jigs, cooler, cases etc. Will try and get a break down.
def different supplier than our 2 lol....still sodding waiting on a price
Have my chinese agent made few phone calls for me and 1delivered machine - $260
is that with ALL the tools accessories for mugs and phones ect and incl deliveryPaul;84063 wrote:Have my chinese agent made few phone calls for me and 1delivered machine - $260
so where justin getting $1000-2000 from ?????
