Our main cushions are 45cm square, printed at 46cm to allow for the cut and sew work. These are printed horizontal with the reverse side print, so a panel of 92cm x 46cm per cushion.
You could get a large flat bed press, but these take up more space, and use more electricity, sometimes just higher wattage than a 13 amp socket, and often three phase)
For smaller fabric work we did on flat bed presses, before getting the rotary press, we didn't have the same consistency as we get from the rotary.
Faux suede cushions
