printer document section
jennywren
Re: printer document section
Post by jennywren »
I have somehow changed a setting in the printer, how can I put it right, hope I can explain this, I need the printer for sub dye in the document section to come up with sRGBEC61966-2 ECT not rgb 1998, it tells me to set pull down menu but how :oops: where is it. I need a idiot guide please if possible. thanks everybody
Should be a drop down arrow to the right of the text. In some versions of PhotoShop Elements you have to use the up and down arrows as Adobe forgot ( :!: ) to include a scroll bar :!: :!: :!:
jennywren
Post by jennywren »
really sorry I must be thick as pigs poo ( sorry pigs) am I suppose to be looking in photo shop :oops: had a look is at the top and what does it say. really sorry but what part of text should I be pressing. might :roll: be easier if you pretend I'm 5
Sorry jennywren, not sure where you're looking now.
jennywren
Post by jennywren »
sorry sorry I knew I would confuse the hell out of you, the problem happens only when I use my a4 template for printing on but I have just noticed when I did a new a4 tenplate the numbers matched on the printer screen. I think the tenplate that I normal use comes out on rgb 1998, why is that. the new one I've done has the number that I want how. Sorry hope I have'nt driven you to drink.
Hic ;)
Would it be just as easy to save the new template and put the change down to one of those wierd things computers do!
jennywren
Post by jennywren »
It was down to you that I found it so many thanks, I would have never found the nerve to fiddle all be that I found it by accident it, if you had not replied to my query. I have done what you've said and done a new template but would have like to know why it happen. Many thanks I am so :D :D :D :D
Great ;)
jennywren
Post by jennywren »
Where was I suppose to be looking, in photo shop or the printer section. :?:
I think the rbg settings you refer to are in PhotoShop. Such options don't exist in the printer setup.
Users browsing this forum: Majestic-12 [Bot] and 5 guests
