Mugs from BMS - Very pleased :-)
Re: Mugs from BMS - Very pleased :-)
Yeah could be, I'm not overly concerned,they look good, I might be expecting too muchScotty@BMS;82595 wrote:You may just be experiencing a bit of overspray. Seen that a lot on desktop Epson printers.
phoenixalpha
If you do a five perfect squares (each one 100% - one of 100% cyan, 100% magenta, 100% yellow and 100% black and then a 5th of 100% in all four colours) in something like Illustrator or a vector program and print that out onto the paper, that will show you if you have overspray or if its the image. A vector image should have a perfect reproduction.
Ok mate I'll give that a go and see what results I get.phoenixalpha;82621 wrote:If you do a five perfect squares (each one 100% - one of 100% cyan, 100% magenta, 100% yellow and 100% black and then a 5th of 100% in all four colours) in something like Illustrator or a vector program and print that out onto the paper, that will show you if you have overspray or if its the image. A vector image should have a perfect reproduction.
