totally confuzzled :(
Maggie
Re: totally confuzzled :(
Post by Maggie »
Golly, I just don't know what to do! Have a feeling I am making this far more complicated than it needs to be but perhaps not....I don't know :(
I have the DF12 mug press and SG3110 printer (bought from BMS a wee - or rather long - while ago and only now biting the bullet)
Have installed the SG3110 and the driver PowerDriverR and now I am meant to configure the design software but I don't use CorelDraw, Illustrator or Photoshop. I mainly use InDesign and Xara (and only a little Elements).
...so will I have to bring the file into Elements (after setting it up in InDesign/Xara) and print from Elements?
Elements is the only programme listed with configuration details that I actually have.
So the design software I have to configure is Elements?
Or am I totally not understanding this?
Maggie;82233 wrote:Golly, I just don't know what to do! Have a feeling I am making this far more complicated than it needs to be but perhaps not....I don't know :(
All you need to do is install the PowerDriver software which was outlined on the flyer that came with the printer and then you can print from any package you want to. If you've misplaced the flyer you need to go to this link and follow the instructions for downloading and installing PowerDriver:
http://www.sawgrasseurope.com/technical ... wer-driver
Maggie
Post by Maggie »
Thanks for your reply. Yip, have the flyer and have been following the instructions on the link. It is step 3 (on the link) that states to configure the software that I am stuck at :(
