One of my Ricoh shows 'Error' next to it when viewing the printers in System Preferences - It works as normal so I hadn't taken any notice of it until recently, its started to bug me now..
Anyone got ANY ideas?
There are no error notifications on the printer display - or on its webpage.
Using FlexiStarter 10 and a Liyu SC631e & a Silhouette Cameo cutter. 2x Ricoh SG3110dn printers and Adkins Auto Clam press. Using Sublijet-r from Sawgrass. ..And I have gotten my money's worth out of this forum - saved Hundreds by being a Premium Member <-- IF you like this post PLEASE add to my reputation by clicking the 'Star' below this post on the Left
probably a stupid question - but you have run the 'troubleshooter'? One of mine did this and we ran that, it found nothing, but cleared the error and no problems since.
On the 'devices and printers' right click on the printer Make it as your default printer or it will throw that up at you, you can always change it back afterwards.
It was a last resort for us, just to try and clear the damn thing and it did the trick
Selected 'Add Printer' but the Sub printer was not showing in the list - only my general Ricoh was.. so I found the IP address of the Sub Printer: 192.168.1.6 in my case and elected to ad the printer via it's IP address.
Now it is showing with a nice green light next to it.
******* Been messing some more, I noticed that the printer I had added just by selecting it from the list would not return the 'Supply Levels' from the 'Utility' tab of the driver but the printer I added by it's IP did return this info even when sleeping so..
I added BOTH pinters now by their IP addresses and they both work as expected now.
In my case they were:
192.168.1.5
192.168.1.6
Now, the next problem is:
I cant select Default paper sizes independently for both printers - for example: I set the default paper for the General printer to A4 and this also sets the Sub printer to the same paper size - this is just a minor gripe but I don't see why I can't set these independently as the printers are on different addresses, they DO share the same driver though.
