intro
squashynose
Re: intro
Post by squashynose »
Hi, I'm Emily, and a friend has been bugging me to sign up on here for a while now (probably so I can stop pestering her with all my questions lol).
I run a business making pet accessories, and a few months ago got a dye sub set up to be able to print pet tags and ribbons/fabrics for collars :)
I'm having a few issues with my printer, and now with my heat press, so hopefully I can find some help on here!
Using Ricoh SG3110DN printer, Sublijet-R inks, and rubbish cheap heat press from Coralgraph!
Bespoke pet accessories, by Leading the Pack
Designandgift
Re: intro
Post by Designandgift »
Hey emily
welcome to the furom
to get the best help it will be useful if you told everyone as much info as you can to save time and questions later
what printer you are using,
what ink and paper
what heat press
then someone will be able to help you out hopefully :)
also what is the problem you are having. with the printer and heat press you have?
NikGrey
Re: intro
Post by NikGrey »
Its a great idea to put details of your setup in your signature - for the reason outlined by D&G above.
As I have here.
Re: intro
Hi Emily and welcome to the forum :-)
DSF Admin
Renniwano
Re: intro
Post by Renniwano »
Great to see you onboard Emily.. and you know I will answer all the questions I can :p - but sometimes even I need help lol and this is where I come :)
squashynose
Re: intro
NikGrey;80550 wrote:Its a great idea to put details of your setup in your signature - for the reason outlined by D&G above.
As I have here.
I tried but couldn't figure out how to do it lol
Thanks for the welcome :)
squashynose
Re: intro
Aha, figured it out :)
