Can you gues what it is yet ?
Re: Can you gues what it is yet ?
I am making a Hydraulic press yes, but for what is the question ?
Another clue - what Paul described as a possible 'Mould' is actually a Blade.
Earl Smith
Your closer than you think Earl.
Here's another image which might help - the cylinder is mounted this way up at the moment so I can install what I need to into the top.. lots of welding to be done as this needs to be strong.
Earl Smith
If you weld the "jack" into the bottom(top) , then use that to compress something into the mould in the bottom when its turned over? Or does the jack have a blade attached so it can cut something?
No idea, sorry.
No idea, sorry.
soulclaimed
i really want to know what this is now nik even googled hydraulic presses but cant see any that look like yours lol
I love your aproche to do thinks nik! I love diy
Dave271069
Ok... someone wants to cut his own things out of something....lol
