A3 size prints needed due to dead printer :-(
parada print
Re: A3 size prints needed due to dead printer :-(
Hi all, I know every one is so busy but my a3 Epson has just packed up. I need 6 images printed for hardboard placemats the print size is 250mm x 312mm so should get 2 onto one sheet. If any one can help please let me know.
parada print
Sorry 2 will not fit onto 1 sheet.
parada print;80033 wrote:Hi all, I know every one is so busy but my a3 Epson has just packed up. I need 6 images printed for hardboard placemats the print size is 250mm x 312mm so should get 2 onto one sheet. If any one can help please let me know.
I can't help as I am too far away, however you will not get two on one sheet, otherwise you would not need A3....
parada print
Thank you for your reply I did think this just after I pressed send. Thanks for your help.
socialgiraffe;80035 wrote:I can't help as I am too far away, however you will not get two on one sheet, otherwise you would not need A3....
- purpledragon
Send me the files and inbox me your address ill tag em on to one of my job sheets ill only charge you the postage and a quid for each print to cover me costs
If you want to pop in on Monday, Scott can sit you down in front of a laptop and our GX7000 A3 printer to do what you want. Can't spend time doing this for you but your welcome to use the laptop and the printer in the demonstration office.parada print;80033 wrote:Hi all, I know every one is so busy but my a3 Epson has just packed up. I need 6 images printed for hardboard placemats the print size is 250mm x 312mm so should get 2 onto one sheet. If any one can help please let me know.
parada print
Thank you so much for the offer but martin is just round the corner from me so i will pop in there. Thanks again.purpledragon;80038 wrote:Send me the files and inbox me your address ill tag em on to one of my job sheets ill only charge you the postage and a quid for each print to cover me costs
parada print
Hi Martin,
Thank you so much for this. I will pop in on Monday. You are a life saver!!!
- purpledragon
no problem glad you got sortedparada print;80045 wrote:Thank you so much for the offer but martin is just round the corner from me so i will pop in there. Thanks again.
