Faded colours
Quinsfan
Re: Faded colours
Post by Quinsfan »
Hi guys and girls
I thought I would add this photo of my first 3 attempts at sublimation. The coaster worked perfectly at the given times and temp. The iPods I am disappointed with. Very little colour transfer. These were cooked at 200 deg for 40 sec, these were the instructions given by Listawood. I know the answer will be try different temps or times but could it be anything else? The paper is Trupix and the printer is Ricoh 3110 no setting were changed from the coasters to the iPods. The coasters were done first I done a set of 4. I think I got my hopes up to early.
[ATTACH=CONFIG]2221[/ATTACH]
vB_ID:2221
vB_ID:2221
spongerobinson
Re: Faded colours
Post by spongerobinson »
did you make sure to take any plastic covering off the phone case metal? I know when we get them, it can be sometimes very hard to see that there is a plastic film on them.
Quinsfan
Re: Faded colours
Post by Quinsfan »
Just had a look cant feel anything. Tried to lift the corner nothing there. I have another case that there is a blue film on that was not on the two I have already done.
spongerobinson
Re: Faded colours
i'm just guessing that may have been it, as there is a distinct shine on the transfer paper in your photograph I think? This doesn't look normal to me, so I'm guessing the plastic may have been left on and it melted onto the transfer paper.
Quinsfan
Re: Faded colours
Post by Quinsfan »
You may be right as I saw that the other protective film was blue I didn't think to check these two as they looked white. They may have had a clear protective film! Also it makes sense as the paper didn't want to peel off easily!!!!!
spongerobinson
Re: Faded colours
try the third one with the blue film off, and you hopefully will be ok! you'd be surprised how hard it can be sometimes to see that a clear film is on!
Quinsfan
Re: Faded colours
Post by Quinsfan »
I just checked the iPad cover I have and there was a clear film on that which I would have never noticed as well. Thanks for the help spongerobinson.
As I am a newbie i'm sure there will be more learning curves coming up.:tongue:
spongerobinson
Re: Faded colours
no problem mate :)
NikGrey
Re: Faded colours
Post by NikGrey »
What are the best type of Coaster for this - and where to find them ? I'm itching for more things to use my new press on.
Quinsfan
Re: Faded colours
Post by Quinsfan »
Nik the ones I have are from Listawood. I took advantage of the 10% discount and bought my printer and paper from them and asked for some samples, which they were kind enough to send me for free.
The coasters are 90 x 90 wooden.
