black ink looking red at bottom of image HELPPPPP lol
Prestigecustomprint
Re: black ink looking red at bottom of image HELPPPPP lol
Post by Prestigecustomprint »
hi guys when i print my image out if i have a black background to it it looks ok i then print it on a mug and boom red is showing through the black i just dont know what is going wrong please help
Dave271069
Post by Dave271069 »
Hello and welcome
start off with a list of all the kit your using and times and temperatures. You will get your answer
dave
Prestigecustomprint
pixmax 5 in1 press
epson xp205 printer with sublimation ink
sublimation paper from monsterdoodle
using photoshop 7 for imaging
360 degree f and 60 seconds from the beep but in the press itself from putting it on so it heats with the press as monsterdoodles told me
cheers most mugs turn out ok just if i have block dark colour its sort of speckled red in the bottom part of the design
What ink?
What printer ICC profile?
Is monsterdoodle the brand or supplier of the paper?
Prestigecustomprint
the ink has no name on it i bought it from amazon just says it is sublimation ink monsterdoodle supplied the paper as their own brand and where would i find the icc profile ?
Dave271069
Not sure if your time is wrong, I would do 180c for 180 seconds from when it reaches it's temperature. I'm sure others are going to tell you too that your inks and papers are not up to the job but that's for you to decide. I started like yourself with cheap inks and papers and was told by many people that I need to swap my inks rct but to this day I'm still using my cheap ones that came with the printer.
next thing is icc which is a profile that tells your printer what inks you are using and prints the right colours, see paul on this site for further details.
dave
Prestigecustomprint;78996 wrote:the ink has no name on it i bought it from amazon just says it is sublimation ink monsterdoodle supplied the paper as their own brand and where would i find the icc profile ?
Interesting post. I'm sure Sawgrass will be following this one up :)
spongerobinson
Post by spongerobinson »
with regards to the monster doodle supplied paper, i know the stuff we got for free with our heat press was of a very low quality, and switching to Trupix made a huge difference.
NikGrey
Post by NikGrey »
I bought the exact same gear as you - replaced the lot already, well almost - just waiting to get some money in and then I will be buying the Auto Clam from xPress.
Was it 'Quality Bits' ink, from amazon by chance?
The Bundled paper is better used in the Bathroom.
MD do give good service though - I am not knocking the company by any means, I have found them very good.
