S21 Cartridge problem
Mattie
Re: S21 Cartridge problem
Post by Mattie »
Hi
I have a Epson S21 printer which i am using the CISS cartridges inside printer (not bottle feed). My black cartridge has all the sudden stopped working but the other 3 colours are working fine.
I have ran serveral cleaning processers but no joy ink is full in the cartridge so i know it's not the ink level
can anyone help me please?
Thank you
Matthew
Can you check if the cartridge is holding a vacuum? Try pulling ink out of the cartridge when the outlet hole is sealed. Does a vacuum form? If not then the cartridge probably has an air leak and needs to be corrected or replaced.
Mattie
Post by Mattie »
Hi
Yeah i checked that cartridge it holds a vacum.
Matthew
Try putting in a normal ink cartridge - does that print? If not then the print head might be blocked. You could try cleaning this with a product such as nozzle rocket (or other print head cleaning solutions) if it does appear blocked.
Mattie
Post by Mattie »
Thanks i'll try that today. i'll let you know if it works
Matthew
Mattie
Post by Mattie »
I've decided just to buy new printer just got sx105 off ebay
Matthew
enviroprintuk wrote:I've decided just to buy new printer just got sx105 off ebay
is that for sublimation??
Mattie
Post by Mattie »
yeah read few articles on net and it's ok for basic items that don't need lots of colours
Matthew
