Yolo v TMT v xpress v etc
GoldRapt
Has thanked: 6 times
Been thanked: 7 times
Re: Yolo v TMT v xpress v etc
Post by GoldRapt »
I look forward to the results of any test on opaque papers.
Thanks for posting your results Dave.
regards
Tony
-launching july/august 2026
Quick update, I've been wash testing my first transfer paper tests. The Yolo Digitrans faded after just three washes but hasn't deteriorated too much since then so I'd be interested in trying out different printer/press settings to possibly help this.
The Xpres Trimfree paper is still as vivid after 6/8 washes as when it was printed.
Dark papers from both are washing well, Xpres again is performing extremely well with no apparent issues after same number of washes.
Dave271069
Post by Dave271069 »
Any wash test on YOLO opique, for dark laser.
Yes, washing very well, better than the white, no apparent issues after 6+washes :-)
GoldRapt
Post by GoldRapt »
Well here the shirt I was taking about with the burnt edges earlier on.
Shirt is an old ladies M&S t-shirt, 100% cotton, Cambodian made. The weave is not as thick to the touch as it is in the photo's.
Paper is Neehan's Jet Soft Pro Stretch from Yolo.
This has been washed four times now, inside out in the washing machine with main coloureds wash at 40 deg. Non bio soap tabs.
You can see the off white "burn" mark around the Q in the 2nd photo it is I believe, not a burn but carrier reside.
[ATTACH=CONFIG]2051[/ATTACH]
[ATTACH=CONFIG]2052[/ATTACH]
vB_ID:2052
vB_ID:2052
vB_ID:2051
vB_ID:2051
regards
Tony
Dave271069
Yolo, if your reading this your Laser OPAQUE is pants!
im fed up of throwing away sheet after sheet because i cant peel the dam thing off and then when i do the toner just does not stay on the paper it smudges every time, ive gone through about 15 sheets over the last few weeks just to make 2 t-shirts. simon, any chance you could print out 1 design for me and put it in a envelope? im loosing the will to live here, i can send it to you in photoshop format if it helps...
[ATTACH=CONFIG]2054[/ATTACH]
Dave
vB_ID:2054
vB_ID:2054
single_09 copy.jpg (69.86 KiB) Viewed 428 times
GoldRapt
Post by GoldRapt »
Sorry to read that Dave, now Simon what would you print it with and on what please?
I suppose the former will be the sp540?
regards
Tony
Dave271069
im hoping simon will do a copy for me on his versacam thats about as much as i know, as for the opaque ive just tried again and the same shit is happening, im sorry but its put me off it for life. i will try and upload some images of what has been happening.
[ATTACH=CONFIG]2055[/ATTACH][ATTACH=CONFIG]2056[/ATTACH][ATTACH=CONFIG]2057[/ATTACH]
vB_ID:2057
vB_ID:2057
vB_ID:2056
vB_ID:2056
vB_ID:2055
vB_ID:2055
Dave271069
what i find is it is so difficult to peel off the backing i end up smudging ripping etc etc the image.. think im going to send a link to this post to there facebook page.
Dave271069
im going to try my luck vinyl me thinks!
