hi vis vests
purpledragon
Re: hi vis vests
Post by purpledragon »
Dave271069;78206 wrote:I kind of did but changed it in the final stages, it was totally my fault. Won't spell scaffolding wrong again though...
sciffol.....scafold....skiffol...... sod it building poles
Re: hi vis vests
building poles
Other nationalities are available.....
Artificial
Re: hi vis vests
Post by Artificial »
Oh no Dave, you must have been so annoyed! Oh well, you got it sorted out in the end... :D
Dave271069
Re: hi vis vests
Post by Dave271069 »
10 hi vis arrived this morning, deciding wether to go vinyl or Sub on them, but one thing for sure I won't be spelling skiffolding wrong again, i mean scaffolding! :tongue:
tlworkwear
Re: hi vis vests
Post by tlworkwear »
vinyl all the way for me on hi vis, looks much crisper when pressed.
Dave271069
Re: hi vis vests
Can they be pressed at normal temp, 160-170c?
tlworkwear
Re: hi vis vests
I normally press at around 150-160c depending on the vinyl.
purpledragon
Re: hi vis vests
Get the sub ink on it dave 190 deg no problem 40 secs. Mine come out crisp n sharp and will never peel
Dave271069
Re: hi vis vests
went vinyl in the end, customer said they never last long with his workers so hopefully will get a repeat order.[ATTACH=CONFIG]2041[/ATTACH]
vB_ID:2041
vB_ID:2041
Dave271069
Re: hi vis vests
